  3. Placement Comparison with two .brd files
  • Subscribers 19
  • Views 10519
karthikeyan123
karthikeyan123 over 7 years ago
Hai,
I want compare the two .brd file for placement comparison it returns the un equaled (Ref des, XY location, Rotation, Mirror check, Symbol name) these five unequaled values want to be generate as a report i dont know how to do in skill code any one can help me please . The result could be form as a report
  • oldmouldy
    oldmouldy over 7 years ago +1
    PCB Editor opens a single board in a session so comparing two boards directly from SKILL, which works with the current board session is not going to provide a direct solution. You could export the Placement…
  • oldmouldy
    PCB Editor opens a single board in a session so comparing two boards directly from SKILL, which works with the current board session is not going to provide a direct solution. You could export the Placement text files from PCB Editor and then compare them, a file comparison utility, some text editors, or a standalone program not related to SKILL, will probably provide a more simple solution to compare the two placements.
