  3. Need a skill code to report text block settings from pcb...
  • Replies 10
  • Subscribers 18
  • Views 16731
Need a skill code to report text block settings from pcb editor.
RagavanT
RagavanT over 7 years ago
Hi Experts,
I was trying to generate a report about text block from PCB editor and output file name should be on footprint name.
Thanks.
  • DE202408202727
    DE202408202727 over 7 years ago +1
    It's difficult to understand what you are asking. Does this help: foreach(def, axlDBGetDesign() ->symdefs p = axlDMOpenFile("MISC", strcat(def ->name, ".txtBlkRpt"), "w") fprintf(p, "%s", buildString…
  • DE202408202727
    DE202408202727 over 7 years ago in reply to RagavanT +1
    Type the whole command axlGetParam("paramTextBlock:1") ->??
  • RagavanT
    RagavanT over 7 years ago in reply to DE202408202727
    Skill > axlGetParam("paramTextBlock:1")
    param:1194166C
  • DE202408202727
  • RagavanT
    Skill > axlGetParam("paramTextBlock:1") ->??
    (objType "paramTextBlock" width 0.4064 photoWidth
    0.0254 name "1" lineSpace 0.7874
    height 0.635 charSpace 0.1524
  • DE202408202727
    So if you copied my code correctly it should work
  • DE202408202727
    DE202408202727 over 7 years ago in reply to DE202408202727
    defun( TextBlockcheck ()
    p = axlDMOpenLog(lsprintf("%s_textblkcheck_Report", axlCurrentDesign()))
    fileName = get_filename(p)
    fprintf(p, "textblkcheck_Report\n\n")
    fprintf(p,"TextBlock:\n\n")
    q=axlGetParam("paramTextBlock:1")
    txtBlk_name = q->name ; get the name field *** Case sensitive ***
    txtBlk_photo = q->photoWidth ; get the photoWidth field
    txtBlk_height = q->height ; get the height filed
    txtBlk_width = q->width ; get the width filed
    txtBlk_linespace = q->lineSpace ; get the lineSpace filed
    txtBlk_charSpace = q->charSpace ; get the charSpace filed
    fprintf(p, "name:%L TxtBlk_Photo:%L txtBlk_height:%L txtBlk_width:%L txtBlk_linespace:%L txtBlk_charSpace:%L", txtBlk_name, txtBlk_photo, txtBlk_height, txtBlk_width, txtBlk_linespace, txtBlk_charSpace)
    axlDMClose(p)
    axlUIViewFileCreate(fileName, "REPORT", nil)
    axlVisibleDesign(t)
    axlMsgPut("Checking completed.See report.")
    ); end defun
