  3. Need a skill code to report text block settings from pcb...
  • Replies 10
  • Subscribers 18
  • Views 16720
Need a skill code to report text block settings from pcb editor.
RagavanT
RagavanT over 7 years ago
Hi Experts,
I was trying to generate a report about text block from PCB editor and output file name should be on footprint name.
Thanks.
  • DE202408202727
    DE202408202727 over 7 years ago +1
    It's difficult to understand what you are asking. Does this help: foreach(def, axlDBGetDesign() ->symdefs p = axlDMOpenFile("MISC", strcat(def ->name, ".txtBlkRpt"), "w") fprintf(p, "%s", buildString…
  • DE202408202727
    DE202408202727 over 7 years ago in reply to RagavanT +1
    Type the whole command axlGetParam("paramTextBlock:1") ->??
  • DE202408202727
    Does this help:
      fprintf(p, "%s", buildString(unique(setof(obj, def ->children, obj ->objType == "text") ~>textBlock)))
      axlDMClose(p)
  • RagavanT
    RagavanT over 7 years ago in reply to DE202408202727
    Hi Dave,
    Thanks for your reply. I am new to skill code, I tried to code extract text block report from the footprint(xxx(fpname)_xxxx(timestamp).txt. Here I want output file should be in the name of footprint name and timestamp. and I don't have an idea to include time and footprint name into an output report file. here the code i composed. please help me to achieve desired code.
    axlCmdRegister("textblkcheck" 'TextBlockcheck)
    defun( TextBlockcheck ()
    p = axlDMOpenLog("textblkcheck_Report")
    fprintf(p, "textblkcheck_Report\n\n", nil)
    fprintf(p,"TextBlock:\n\n", nil )
    q=axlGetParam("paramTextBlock:1")
    txtBlk_name = q->Name ; get the name field
    txtBlk_photo = q->PhotoWidth ; get the photoWidth field
    txtBlk_height = q->Height ; get the height filed
    txtBlk_width = q->Width ; get the width filed
    txtBlk_linespace = q->LineSpace ; get the lineSpace filed
    txtBlk_charSpace = q->CharSpace ; get the charSpace filed
    fprintf(p, "name:%L TxtBlk_Photo:%L txtBlk_height:%L txtBlk_width:%L txtBlk_linespace:%L txtBlk_charSpace:%L", txtBlk_name, txtBlk_photo, txtBlk_height, txtBlk_width, txtBlk_linespace, txtBlk_charSpace)
    axlDMClose(p)
    axlUIViewFileCreate("textblkcheck_Report.log" sprintf(nil, "REPORT", nil), nil)
    axlVisibleDesign(t)
    axlMsgPut("Checking completed.See report.")
    ); end defun
    Ragavan T
  • DE202408202727
    Take care with case sensitivity.
    Tr=y this:
    defun( RagavanT_TextBlockcheck ()
    p = axlDMOpenLog(lsprintf("%s_textblkcheck_Report", axlCurrentDesign()))
    fileName = get_filename(p)
    fprintf(p, "textblkcheck_Report\n\n")
    fprintf(p,"TextBlock:\n\n")
    txtBlk_name = q->name ; get the name field *** Case sensitive ***
    txtBlk_photo = q->photoWidth ; get the photoWidth field
    txtBlk_height = q->height ; get the height filed
    txtBlk_width = q->width ; get the width filed
    txtBlk_linespace = q->lineSpace ; get the lineSpace filed
    txtBlk_charSpace = q->charSpace ; get the charSpace filed
    axlDMClose(p)
    axlUIViewFileCreate(fileName, "REPORT", nil)
    axlVisibleDesign(t)
    ); end defun
  • RagavanT
    Hi Dave,
    i copied this code checked ,it not working, even file name was"textblkcheck_Report" and fields were not actual values.
    Fullscreen 4861.textblkcheck_Report.log Download
    textblkcheck_Report
    TextBlock:
    name:nil TxtBlk_Photo:nil txtBlk_height:nil txtBlk_width:nil txtBlk_linespace:nil txtBlk_charSpace:nil
    output report file attached
    Ragavan T
  • DE202408202727
    What is the result when you type axlGetParam("paramTextBlock:1") ->?? on the SKill command line?
