  3. Mirroring in Bottom of Bottom
  • Subscribers 18
  • Views 12227
vimaldevlpr
vimaldevlpr over 7 years ago
Hai,
I have a doubt in mirror object  axlTransformObject-  ?mirror  'GEOMETRY  i used this for mirroring an object in same layer its only works in top layer bottom it is not working how to i do this in bottom for same layer using skill please any one guide me i share my conditions used.
axlDBTransactionMark(vm)
          if(mirror_objs then
        b = 'GEOMETRY
            axlTransformObject(mirror_objs, ?mirror b ?angle 180.0 ?allOrNone nil)
          ); endif
    ); end while
While Using Top layer Its mirrored in TOP layer Its working fine But in Bottom Layer We used Means it moved to TOP I Want to Mirror same in Bottom how to solve this problem Any one guide me please.
  • DE202408202727
    DE202408202727 over 7 years ago
    Do't use angle
    axlTransformObject(mirror_objs, ?mirror 'GEOMETRY)
  • Jason Hsu
    Jason Hsu over 7 years ago in reply to DE202408202727
    Hi Dave,
      I have a question for "rotate" in axlTransformObject. I want to rotate 8 circle shape 22.5(360.0/8/2) degree in a counter-clockwise. No matter what I rotate all of 8 shapes only once or rotate them one by one. It seems the result has some offset. The circle shape isn't the center between two pins. The shape isn't symmetrical by X or Y axial. (I think rotate is simple than calculate the coordinate, then add the shape.) If do you know why? Could you please help me on it. Thanks in advance.
    global:         axlTransformObject(l_dbid ?angle 22.5)
    individual:   axlTransformObject(dbid ?angle 22.5 ?origin 0:0)
    Best Regards,
    Jason
  • DE202408202727
    DE202408202727 over 7 years ago in reply to Jason Hsu
    Hi Jason, I had trouble emulating what you are seeing until I set my design accuracy to 1. Then I get strange results. What design accuracy are you using?
  • Jason Hsu
    Hi Dave,
      Thank you for your reply. I setup the accuracy to 2 or 4,it always has some offset. I will use 1 tomorrow. Now,I attempt axlCopyObject,the angle is a variable,by make use of for loop. It looks good. Thanks a lot for your help.
    Best Regards
    Jason
