  3. Board file use.
  • Subscribers 19
  • Views 10276
Board file use.
vimaldevlpr
vimaldevlpr over 7 years ago
Hai,
I would like to do take another .brd file report  while running the skill code in current .brd file  For examole :1.brd  is file and 2.brd is other file here in the tool i opened 1.brd file in that i want to take report of  2.brd file for that i used this attaeched skill code.
procedure(plac()
out=outfile("report.rpt")
file = axlDMFileBrowse(nil nil ?optFilters "BRD Files|*.brd|")
foreach(cmp, axlDBGetDesign() ->components
when(cmp ->symbol
a = cmp ->name
inList = a
fprintf(out, "\n%L", inList)
Here by this code it return only the current board file report i want to get 2.brd report file can you say it is possible if it possible please say how to do it.
  • B Bruekers
    B Bruekers over 7 years ago
    Allegro can only work with 1 openend database at a time, so you need to switch the current design during the Skill program.
    Try something like this:
    procedure(plac()
        let( (currentDesign file out)
        currentDesign = axlGetDrawingName()
        axlSaveDesign(?design axlCurrentDesign() ?noConfirm t)
        when(axlOpenDesignForBatch(file "wf")
            if(out=outfile("report.rpt")
            then
                    when(cmp ->symbol
                        fprintf(out, "\n%L", cmp->name)
                close(out)
            else
                print("Can not open file for writing")
        axlOpenDesignForBatch(currentDesign "wf")
  • vimaldevlpr
    vimaldevlpr over 7 years ago in reply to B Bruekers
    Thanks lott working fine.
