  3. Report with List.
  • Subscribers 18
  • Views 12107
Report with List.
vimaldevlpr
vimaldevlpr over 7 years ago
Hai,
I have two report in that i want generate a new report for equal refdes values i used some codes they were attached below.
procedure( compare()
out=outfile("report.rpt")
in1=infile("report1.rpt")
in2=infile("report2.rpt")
while(gets (str, in1)
if(str != nil then
inList = parseString(str ",")
a=car(inList)
while(gets (str1, in2)
if(str1 != nil then
inList = parseString(str1 ",")
b=car(inList)
(foreach x a
(foreach y b
if(x == y then
fprintf(out,"\n%L",x)
close(out)
close(in1)
close(in2)
For this it comes error; E-*Error* foreach: second argumentt must be a list
For example
Report1:                       Report2:
abc                                abc
bsd                                bcd
ccc                                 ccc
Result:
abc
ccc
Please anybody knows  share me the skill code i dont know how to do this.
  • DE202408202727
    DE202408202727 over 7 years ago
    procedure( vimaldevlpr_compare()
    let((out, in1, in2, str, x, inList)
    while(gets(str, in1)
    when(str
    x = car(parseString(str ",\n"))
    inList = cons(x, inList)
    close(in1)
    while(gets(str, in2)
    when(str
    foreach(y inList
    when(x == y
    fprintf(out,"\n%L", x)
    close(out)
    close(in2)
  • vimaldevlpr
    vimaldevlpr over 7 years ago in reply to DE202408202727
    Thanks for the reply sir
    I have an another doubt  can you please help me.
    here it check for one list i want to check multiple fiels in different list  i have attached the code
    let((out, in1, in2, str, x, v,  inList, inList1)
    when(str
    v = cdr(parseString(str ",\n"))
    inList1 = cons(v, inList)
    close(in1)
    when(str
    foreach(y inList
    foreach(m inList1
    if(x == y && v ==m then
    print("True")
    else
    fprintf(out,"\n%L,%s", x, "False")
    close(out)
    For example"
    Report 1:        Report 2:
    Ref des                   Symname                                           Ref des                      Sym name
    abc                           123                                                       abc                              123
    bcd                           444                                                        bcd                              555
    ddd                           555                                                        ddd                             666
    Result:
    Ref des                  Symname
    bcd                          False
    ddd                          False
    As like this methods i have to do  can please guide me how to do.
  • B Bruekers
    B Bruekers over 7 years ago in reply to vimaldevlpr
    I would personally use a hash table for this. With this you can store a refdes vs symname. The check with report 2 is then also esier:
        let( (out, in1, in2, str, x, v,  data)
        data = makeTable("data")
            when(str
                data[x] = v
        close(in1)
            when(str
                if(data[x]
                then
                    ;refdes present, check for correct sym name
                    if(data[x] == v
                    then
                        print("True")
                    else
                        fprintf(out,"\n%L,%s: %s - %s", x, "False", data[x], v)
                else
                    ;refdes unknown
                    fprintf(out,"\n%L,%s", x, "Unknown")
        close(out)
    Bram
  • vimaldevlpr
    vimaldevlpr over 7 years ago in reply to B Bruekers
    Thank you For your reply Bram
    It comes for me E- *Error*fprintf/sprintf: format spec: incompatible with data- "Format is "\n%L,%s: %s - %s', argument #3 is (\"\\\"RESC1608X58NA\\\"\")"
    please say how to clear this
  • B Bruekers
    An example report file would be handy to have.
    The issue that i see is that cdr() returns a list, printing a list with %s does not work.
    Change the lines with cdr() to this:
    v = cadr(parseString(str ",\n"))
    This will return the 2nd element of the parsed string, hopefully that is the field which you are looking for.
    If the report is more complex then it is better to use a regular expression to extract the information you need.
