  3. Error in axlAirGap 16.6
  • Subscribers 19
  • Views 9223
luanvn81
luanvn81 over 7 years ago
Hi all!
I have a code use axlAirGap  to check cline and via(shape). It's work on 17.2, but when I run my skill in 16.6, it don't work. I found that when using the command "show measure" on 16.6,  button "Cline" on tap Find  is hidden. How can I solve this problem. Please help me.
Thanks alot.
Luan.
  • oldmouldy
    oldmouldy over 7 years ago
    The 16.6 axlAirGap function, and the related "show measure" command, does not support CLines. The axlAirGap function, and the related "show measure" command, was changed between 16.6 and 17.2 to support additional object types. If you want one SKILL routine for both 16.6 and 17.2, you would need to process CLine Segs.
    • Vote Up -1 Vote Down
