  3. Access skill variable in .scr script
  • Subscribers 19
  • Views 11707
olov
olov over 7 years ago
I'm trying to write a script that will automate the gerber output process. To do this properly I would like to use parameter data (e.g. article numbe for the board) that is stored in a file to control the output files prefix.
When in skill mode I have no problem accessing this information, but now to the problem.
When starting the gerber output I use a .scr file with following content:
setwindow pcb
artwork
setwindow form.film_control
FORM film_control filename_prefix 12345678
FORM film_control select_all
FORM film_control database_check NO
FORM film_control create
FORM film_control cancel
The prefix, e.g. 12345678, I would like to be able to change based on the parameter I can access when in skill mode:
skill Parameters["hq_pcb_article"]
but I cannot fidn a way to transfer this information between these two domains? any ideas?
BR Olov
  • DavidJHutchins
    DavidJHutchins over 7 years ago
    I would try replacing the line:
    with something like the following:
    skill axlShell(strcat("FORM film_control filename_prefix " Parameters["hq_pcb_article"])))
  • Ejlersen
    Ejlersen over 7 years ago
    Hi
    I would recommend that you stick with SKILL for automation whenever possible.
    SKILL is more robust across releases than scripting
    Best regards
    Ole
  • olov
    DavidJHutchins
    Thanks!
    Works great
    Ejlersen OK, sounds like a good approach. Do you have any input on what skill commands to use to do the corresponding to above, i.e. generate the output gerber files?
    BR Olov
  • Ejlersen
    Ejlersen over 7 years ago in reply to olov
    you would use axlRunBatchDBProgram with artwork command
    Make sure to read documentation for both axlRunBatchDBProgram above and also artwork.txt in folder below which shows the commandl ine options you need to pass when using axlRunBatchDBProgram with artwork
    C:\Cadence\SPB_17.2\share\pcb\batchhelp\
    Best regards
    Ole
