  3. axlTriggerSet failing asking for a function
  • Subscribers 20
  • Views 10767
emldebh61
emldebh61 over 7 years ago
I have a procedure called Set_class_title
procedure( _set_class_title(t_open)
dc=axlDBGetDesign()->prop->DESIGN_CLASS
axlSetVariable("DESIGN_CLASS" dc)
);end proc
I want it to run every time I open a new PCB file in Allegro
I have placed the line
axlTriggerSet('open 'set_class_title) in my allegro.ilinit file
When I run Allegro I get an error
W- *WARNING* Symbol set_class_title is not a function.
Any thoughts
Thanks in advance
  • B Bruekers
    B Bruekers over 7 years ago
    The procedure needs to be loaded before you can set the trigger. So first load the code, then set the trigger.
  • emldebh61
    emldebh61 over 7 years ago in reply to B Bruekers
    OK I will take a look and see if I am not doing that. The code appears to work despite the warning ?
  • DavidJHutchins
    DavidJHutchins over 7 years ago
    Your axlTriggerSet call doesn't have the correct procedure name, please try the following:
    axlTriggerSet('open '_set_class_title)
