  3. How to Extract segment length info from Constraint Information...
  • Subscribers 19
  • Views 10477
How to Extract segment length info from Constraint Information in SKILL
Ahmed0ms
Ahmed0ms over 7 years ago
Is there a function to extract the info in the blue circles (pin/via locations and cline segment length and layer) in SKILL?
  • DavidJHutchins
    DavidJHutchins over 6 years ago
    The information you are requesting is available directly from Allegro, the skill access to data in Constraint Manager is extremely limited IMHO
    Below is some example skill code that will report the net data in a format somewhat like the data in blue:
    procedure((Report_nets)
    let((units accur net)
    (axlSetFindFilter ?enabled list("noall" "nets") ?onButtons list("noall" "nets"))
    (units = car((axlDBGetDesignUnits)))
    (accur = sprintf(accur "%%.%df" cadr((axlDBGetDesignUnits))))
    (mypopup = axlUIPopupDefine( nil (list (list "Done" 'axlFinishEnterFun) (list "Cancel" 'axlCancelEnterFun))))
    axlUIPopupSet( mypopup)
    while((axlSelect ?prompt "Select a net...")
    (net = car(axlGetSelSet()))
    when(net
    foreach(branch (net->branches)
    foreach(child (branch->children)
    if(((child->objType) == "pin") then
    axlMsgPut(" (%f:%f) pin %s.%s %s %s" xCoord(child->xy) yCoord(child->xy) child->component->name child->number car(child->startEnd) cadr(child->startEnd))
    if(((child->objType) == "via") then
    axlMsgPut(" (%f:%f) via %s %s %s" xCoord(child->xy) yCoord(child->xy) child->name car(child->startEnd) cadr(child->startEnd))
    if(((child->objType) == "path") then
    axlMsgPut("%f %s cline %s" axlDBGetLength(child) units child->layer)
    axlCmdRegister("report_nets" 'Report_nets)
    Below is the Allegro transcript from running this skill code:
    Command > report_nets
    Select a net...
    Loading axlcore.cxt
    last pick: 1096.94 1280.59
    856.099298 mils cline ETCH/TOP
    (1373.370000:1040.560000) via V_C18P8_PLUG ETCH/TOP ETCH/BOTTOM
    (1373.370000:1040.560000) pin U8.AF26 ETCH/TOP ETCH/TOP
    (1010.000000:1316.500000) via V_C20P10 ETCH/TOP ETCH/BOTTOM
    692.703969 mils cline ETCH/L12-SIGNAL
    (615.760000:738.390000) pin J5001.25 ETCH/TOP ETCH/TOP
    Select a net...
    last pick: 1069.65 1269.68
    856.120678 mils cline ETCH/TOP
    (1373.370000:1001.190000) pin U8.AF28 ETCH/TOP ETCH/TOP
    (1373.370000:1001.190000) via V_C18P8_PLUG ETCH/TOP ETCH/BOTTOM
    (1010.000000:1273.500000) via V_C20P10 ETCH/TOP ETCH/BOTTOM
    692.692038 mils cline ETCH/L12-SIGNAL
    (615.760000:706.890000) pin J5001.24 ETCH/TOP ETCH/TOP
    Select a net...
    Command >
