  3. use axlDBChangeText
  • Replies 7
  • Subscribers 19
  • Views 13514
use axlDBChangeText
did31
did31 over 6 years ago
Hi, I would like to change a text with "axlDBChangeText" but being a novice I must miss something in my code.
Example:
let((b, textBlocks, text)
axlClearSelSet()
axlVisibleDesign(nil)
axlVisibleLayer("REF DES/ASSEMBLY_TOP" t)
axlSelectByName("SYMTYPE" "1206", "REF DES/ASSEMBLY_TOP") ; search and select a refdes 1206
axlAddSelectAll()
b = axlGetSelSet() ; for a o_dbid
axlDBChangeText( car(b) 'refdes nil 1); *WARNING* (axlDBChangeText): Require a text dbid, dbid:00000208B4AD8240
could someone help me out ?
sorry for my english thank you
  • DavidJHutchins
    DavidJHutchins over 6 years ago
    Try replacing the 'when(' line with the following to see if the symbol name contains 1206
    when(nindex(refdes->parent->name "1206")
  • did31
    did31 over 6 years ago in reply to DavidJHutchins
    Thank you so much David, it's perfect.
