  3. use axlDBChangeText
  • Replies 7
  • Subscribers 19
  • Views 13513
use axlDBChangeText
did31
did31 over 6 years ago
Hi, I would like to change a text with "axlDBChangeText" but being a novice I must miss something in my code.
Example:
let((b, textBlocks, text)
axlClearSelSet()
axlVisibleDesign(nil)
axlVisibleLayer("REF DES/ASSEMBLY_TOP" t)
axlSelectByName("SYMTYPE" "1206", "REF DES/ASSEMBLY_TOP") ; search and select a refdes 1206
axlAddSelectAll()
b = axlGetSelSet() ; for a o_dbid
axlDBChangeText( car(b) 'refdes nil 1); *WARNING* (axlDBChangeText): Require a text dbid, dbid:00000208B4AD8240
could someone help me out ?
sorry for my english thank you
  • DavidJHutchins
    DavidJHutchins over 6 years ago
    Try adding the following line after the axlVisibleLayer() entry:
    (axlSetFindFilter ?enabled (list "noall" "text") ?onButtons (list "text"))
  • did31
    did31 over 6 years ago in reply to DavidJHutchins
    Thank you David but your function select all text and my code for select only refdes of 1206 it's ok.
    With your function, i have a same message.
  • did31
    did31 over 6 years ago in reply to did31
    hi David, effectively "axlSendFindFilter" it's ok.
    My new code :
    let((refselect, refdes, text)
    axlClearSelSet()
    axlSetFindFilter(?enabled (list "noall" "text") ?onButtons (list "text"))
    axlAddSelectAll()
    refselect = axlGetSelSet()
    refdes = car(refselect)
    foreach( refdes axlGetSelSet()
    text = refdes->text
    axlDBChangeText( refdes nil 1)
    ));end
    It's ok but all text it's changed. How to change only text with footprint 1206 ? An idea ?
    Thank you.
  • DavidJHutchins
    DavidJHutchins over 6 years ago in reply to did31
    Try adding the following after the foreach( line:
    when(refdes->parent->name ==  "1206")
    and another ) before the "));" end line
  • did31
    Yes, it's perfect.
    Do you know if we can do an equal of style "1206*" ? Because my footprint 1206 have many termination.
    In any case thank you for these answers it helps me a lot.
    Thank's David
