  3. Toggle ratsnest display via SKILL
  • Subscribers 19
  • Views 9620
fluxonator
fluxonator over 6 years ago
Hi all
I have a short SKILL question: I want to toggle the ratsnest display between jogged and straight using SKILL. I use axlDBDisplayControl('ratsnestJog, nil) to set it to straight but using axlDBDisplayControl('ratsnestJog, t) to set it back to jogged doesn't work (axlDBDisplayControl('ratsnestJog t) doesn't work either). Am I doing something wrong?
Martin Ostermayer
  • oldmouldy
    oldmouldy over 6 years ago
    Hi Martin, I would say that this isn't working, in that, change to "straight" works but change to "jogged" does not. You might want to raise a case with Cadence, or through your Channel Partner, to get the intended purpose of this function confirmed and, potentially, fixed.
