  3. How could I get the "Referenced Physical Cset “of the selected...
  • Subscribers 19
  • Views 2711
How could I get the "Referenced Physical Cset “of the selected diff pairs using Skill codes?
Roser
Roser over 6 years ago
Hi all !
I can only get the "Referenced Physical Cset “ of the "NetGroup " or "NetClass".
Is there any way to do that?
  • DavidJHutchins
    DavidJHutchins over 6 years ago
    Hopefully I understood your request, I started this by using 'show element' on a net that's part of a diff-pair, then issued the following in a skill window:
    Skill > net=car(axlGetSelSet())
    Loading signal.cxt
    dbid:344782920
    Skill > dp=net->diffpair
    dbid:349467880
    Skill > pg=car(dp->parentGroups)
    dbid:345434568
    Skill > pl=pg->prop
    propList:312991780
    Skill > get(pl,"PHYSICAL_CONSTRAINT_SET")
    "85OHM_DIFF"
    Skill >
  • Roser
    Roser over 6 years ago in reply to DavidJHutchins
    thanks for your reply!
    but this  method  still return the Cset of the "NetGroup " or "NetClass",
    I wanted to know that how can i get the Cset of select diff pairs without "NetGroup " or "NetClass".
    thanks all the same!
