  3. Quick reports generation using skill
  • Subscribers 19
  • Views 11624
rish87
rish87 over 6 years ago
Is there any function in allegro skill to generate quick reports in pcb editor and write the same to a text or html file.
harish
  • ePeter
    ePeter over 6 years ago
    Maybe you can call with axlRunBatchDBProgram the report command ?
    switches for the report command can be found in %CDSROOT%\share\pcb\batchhelp\report.txt
    Otherwise I think you have to write your own report routine.
    Something like this (this will report all pins of one component with Ref Des,Pin Number,Die Pin,X-Coord,Y-Coord,Net Name ),
    defun( report_for_model (Comp_to_select)
     if( axlOKToProceed() then
     units = car(axlDBGetDesignUnits())
      cond(
       (equal(units "microns")  (conv_factor = 1));
       (equal(units "millimeters") (conv_factor = 1000));
       (equal(units "centimeters") (conv_factor = 10000));
       (equal(units "mils")   (conv_factor = 25.4));
       (equal(units "inches")   (conv_factor = 25400)  );
      ) ; end of cond
     sel_pin=axlSelectByName("PIN" strcat(Comp_to_select ".*") t)
     if(length(sel_pin) <=0 then
      printf("E- Component %s not found.\n" Comp_to_select)
     else
      Pin_List = axlGetSelSet()
      axlClearSelSet()
      Report_to="report_for_model.csv"
      report_file = axlDMOpenLog(Report_to)
      count_col_pins=0
      fprintf(report_file,"Ref Des,Pin Number,Die Pin,X-Coord,Y-Coord,Net Name \n" )
       foreach(sPin Pin_List
        refdes = sPin->parent->refdes
        pad_number=sPin->number
        pad_name=pad_number
        ;xy_coord=sPin->xy
        pin_x=car(sPin->xy)*conv_factor
        pin_y=cadr(sPin->xy)*conv_factor
        net_name=sPin->net->name
        fprintf(report_file,"%s,%s,%s,%f,%f,%s\n",refdes,pad_number,pad_name,pin_x,pin_y,net_name )
      axlDMClose(report_file)
      else
       printf("E- Please terminate your interactive command .\n")
      );end-if
