  3. How to reload a SKILL-script in Allegro
  • Subscribers 20
  • Views 16100
Quist
Quist over 6 years ago
I am working on some SKILL scripts which are loaded by allegro.ilinit at startup.
If I edit my .il-files how do I get them updated in Allegro?
Right now I restart the program but there must be a simpler way.
A newbie question, I know...  Grin
  • DavidJHutchins
    DavidJHutchins over 6 years ago +1
    Skill requires the use of Unix style pathnames ( i.e. / instead of \\ ), below is a couple of example alias entries in my env file for reloading a skill file I developed for a client: alias smtc '(load…
  • B Bruekers
    B Bruekers over 6 years ago
    Just use load("yourSkillFile.il").
    If you put this in a defun() then you can even call this from the SKILL prompt with a 'shortcut'. Like:
    defun( aa ()
     load("yourSkillFile1.il")
     load("yourSkillFile2.il")
    Now when you type 'aa' in the skill prompt these files are (re)loaded.
    To get a seperate SKILL prompt type this in the Allegro command line:  set telskill
    Kr, Bram
  • Quist
    Quist over 6 years ago in reply to B Bruekers
    Thanks, but I don't get it to work.  Blush
    The files are in my $CDS_SITE\SKILL folder but if I only write the file name I get: *Error* load: can't access file - "filename.il"
    I have then tried to give the full path but then I get errors on backslashes....
  • DavidJHutchins
    alias smtc '(load "c:/users/davidh/documents/smtc.il")'
    alias tsc '(load "c:/users/davidh/documents/tsc.il")'
  • Quist
    Quist over 6 years ago in reply to DavidJHutchins
    Thanks, now it works!
