  3. PCB Editor SKILL program for finding pin location
  • Subscribers 19
  • Views 15246
Thinker5112
Thinker5112 over 6 years ago
I wanted to find the location of a pin in the design using skill program. pin_dbids = axlDBGetDesign()->pins, this gives me all the dbids of the pins that are present in my design. But when im entering that dbid, pad = axlDBGetPad("000001EA8FD8B9F8" "package geometry/assembly_top" "regular") it is throwing an error stating "This dbid is not user defined. Please enter the user defined". So please provide me a snippet so that I can get the exact pin location in the design using skill script.
  • DE202408202727
    DE202408202727 over 6 years ago in reply to Thinker5112 +1
    To get a pad: pin_dbid = car( axlDBGetDesign()->pins) pad = axlDBGetPad(pin_dbid "package geometry/assembly_top" "regular") pin_dbid ->xy will give you the location of a pin
  • DavidJHutchins
    DavidJHutchins over 6 years ago
    I think your issue is that you are passing the pin dbid as a string value by including it within the "" delimiters...
  • Thinker5112
    Thinker5112 over 6 years ago in reply to DavidJHutchins
    So, how should I pass that? I even tried without using " " delimiters. Even then I have encountered the same issue. Is there any code snippet which gives me the location of a pin?
  • DE202408202727
    To get a pad:
    pin_dbid = car(axlDBGetDesign()->pins)
  • Thinker5112
    Thinker5112 over 6 years ago in reply to DE202408202727
    Thank you Dave. It worked.
  • Thinker5112
    Hi Dave, is there any way that we can get the lower right and upper left coordinates of a bBox?
