  3. Breaking a clineseg into multiple segments with SKILL c...
  • Subscribers 19
  • Views 11719
Breaking a clineseg into multiple segments with SKILL code
leto
leto over 6 years ago
Hello All,
May I know if there is a way to breakup a selected clinesegment into a few clinesegments by just using SKILL code
Thanks All
  • cdlep
    cdlep over 6 years ago
    Play with the following code.
    l_net = axlDBGetDesign()->nets
    foreach(net l_net
    l_branch = net->branches
    foreach(branch l_branch
    l_child = branch->children
    foreach(child l_child
    if(child->objType == "path" then
    l_seg = child->segments
    foreach(seg l_seg
    printf("%L %L\n" seg->layer seg->startEnd)
  • leto
    leto over 6 years ago in reply to cdlep
    Hello Cdlep,
    Thank you for replying my query. The code you suggested help to select the individual clineseg within the design.
    However what I wanted to do was to modify an individual clineseg (which I already selected) to have different widths along it (such as neck down the clineseg at certain locations)
    Individually, I can modify a segment width, however I would need to first breakup the segment into multiple segments.  Need help here.
    Alternately, I can just get the startEnd of the clineSeg and reroute with different widths within the straight line (If there is any easier way I can avoid this).
    Thanks All
