  3. using skill++ with forms. Need to understand variable/function...
  • Subscribers 18
  • Views 2845
using skill++ with forms. Need to understand variable/function scopes with forms.
sunburnt63
sunburnt63 over 6 years ago
I am trying to use the below skill++ code to create a form in Allegro, but I get errors because the following items are hidden in the scope of the showForm function:
  • initializeRows function
  • formCallback function
  • entries variable
I would prefer not to use global functions or variable for these. Is there a way to maintain the encapsulation of these items while getting it to work? The code is below:
procedure( showForm(entries)
  procedure( initializeColumns() ... )
  procedure( initializeRows(entries) ... )
  procedure( formCallback(param) ... )
  formStructure = getFormStructure()
  form = axlFormCreate( gensym(), list("Entry Form" formStructure), nil, 'formCallback, nil )
  initializeColumns()
  axlFormGridInsertRows( form "grid" 0 length( entries ) )
  axlFormGridSetBatch( form "grid" 'initializeRows 'entries)
  axlFormDisplay( form )
