  3. PCB Editor: SKILL script forSelecting Which Script to Replay...
  • Subscribers 19
  • Views 10653
PCB Editor: SKILL script forSelecting Which Script to Replay based on Available Films
VeejayVela
VeejayVela over 6 years ago
I have a SKILL script that basically determines which script to replay (for plotting to PDF) based on available films in the design.
FILMS: FAB1, FAB2, ASY1, ASY2
Some designs would not have the xxx2 film
When I replay my script directly, it works perfectly.
But when I run it through SKILL, it gives out error (looks like it cannot focus on the UI windows that pops out while replaying the script)
Can't find window; form.fpfileplotsetup
Below is my SKILL program:
defun( pp_plotPDF ()
                let( (dbid_film a2 f2)
                                a2 = "FALSE"
                                f2 = "FALSE"
                                dbid_film = axlGetParam("artwork")
                                foreach(filmgp dbid_film->groupMembers
                                                if( filmgp == "FAB2" then f2 = "TRUE")
                                                if( filmgp == "ASY2" then a2 = "TRUE")
                                ) ; end foreach
                                if( f2 == "TRUE" then
                                                if( a2 == "TRUE" then
        ; Both ASY2 & FAB2 present. PLOT BOTH
        axlShell(sprintf(nil, "replay plotPDF4"))
                                                else
        ; Both FAB & ASY1 present. PLOT Fab1, Fab2 & A1 only
        axlShell(sprintf(nil, "replay plotPDF2"))
                                                ); end if
                                else
        ; Fab1 and both ASY present. PLOT Fab1 only and both ASY
        axlShell(sprintf(nil, "replay plotPDF3"))
                                                else
        ; ASY1 and FAB1 present. PLOT Fab1 only and ASY1 only
        axlShell(sprintf(nil, "replay plotPDF1"))
                                                ); end if
                                ); end if
                ); end let
); end defun
Any suggestions on what i'm doing wrong here?
Thanks.
Vijay Anandh Vela
  • DavidJHutchins
    DavidJHutchins over 6 years ago +1
    I tested this skill code & didn't see any issues... I think the error might be due to some issue in the .scr files you are running
  • DavidJHutchins
  • VeejayVela
    VeejayVela over 6 years ago in reply to DavidJHutchins
    Hi David,
    Did some checking on the .scr file and manage to find out what was causing the problem.
    It was previously calling the pp_plotPDF function through a registered command (smt pp_plotPDF)
    I changed the .scr file to instead call (skill pp_plotPDF) and everything is working perfectly now.
    Thank you
