  3. Set layer color with RGB than index using skill
  • Subscribers 20
  • Views 9908
ENEGUE
ENEGUE over 6 years ago
Hello everyone,
is there a way to set new added layer color by using RGB than index? as every user might define the index color differently.
Eugene
  • steve
    steve over 6 years ago
    Yes - If you click the blank color you get the following which will allow you to define the color you want.
  • ENEGUE
    ENEGUE over 5 years ago in reply to steve
    Nice!, it is possible implement it using skill code?
  • DavidJHutchins
    DavidJHutchins over 5 years ago
    I wrote the code below this morning, it's almost working correctly...
    It will look for a color that matches the input rgb values & report it if found, otherwise it will find an unused color & set it to the input rgb values
    procedure((set_rgb_color @optional (Red -1) (Green -1) (Blue -1))
    let((Fail Colors ColorArr ColorUsed ColorList Layer Ptr String)
    (Fail = nil)
    (Ptr = nil)
    (Red = atoi(Red))
    (Green = atoi(Green))
    (Blue = atoi(Blue))
    printf("Red %L Green %L Blue %L\n" Red Green Blue)
    or(minusp(Red) minusp(Green) minusp(Blue) not(fixp(Red)) not(fixp(Green)) not(fixp(Blue))
    axlMsgPut("Red Green Blue values not positive integers; requires 3 int values between 0 to 255")
    (Fail = t)
    unless(Fail
    declare(ColorArr[193])
    (ColorList = axlColorGet('all))
    for(i 1 192
    (Colors = car(ColorList))
    (ColorArr[i] = Colors);
    (ColorList = cdr(ColorList))
    unless(Ptr
    when(eq(nth(0 Colors) Red) && eq(nth(1 Colors) Green) && eq(nth(2 Colors) Blue)
    (Ptr = i)
    axlMsgPut("color %d matches input RGB values %d %d %d" Ptr nth(0 Colors) nth(1 Colors) nth(2 Colors))
    unless(Ptr
    ; declare array & initialize to 0 values
    declare(ColorUsed[193])
    for(i 1 192
    ColorUsed[i] = 0;
    foreach(Class ((axlGetParam "paramLayerGroup")->groupMembers)
    foreach(SubClass ((axlGetParam sprintf(String "paramLayerGroup:%s/paramLayer" Class))->groupMembers)
    (Layer = (axlGetParam sprintf(String "paramLayerGroup:%s/paramLayer:%s" Class SubClass)))
    ColorUsed[Layer->color] = 1;
    for(i 25 192
    unless(Ptr
    when(eq(ColorUsed[i] 0)
    (Ptr = i)
    (Fail = axlColorSet(Ptr list(Red Green Blue)))
    if(Fail then
    axlMsgPut("color %d set to RGB values %d %d %d" Ptr Red Green Blue)
    else
    axlMsgPut("axlColorSet() failed")
