  3. logical AND of two shapes using skill
  • Subscribers 18
  • Views 11009
HighFive
HighFive over 6 years ago
So I've run into a wall,
I've been trying  to AND two shapes together using skill, so far without success. The goal is to get the intersection of the two shapes, the intersection being a size limiting bounding box. I'll list what I'm doing, and what's not working, maybe you guys can offer some insights.
I have two shapes, they were constructed using axlDBCreateShape. I want to AND these two shapes together, and keep only the geometry that intersects both shapes. From reading online, this should be possible using
axlPolyOperation. So far, axlPolyOperation always return nil. This is not an issue of the shapes not having overlapping geometries, the shapes are right on top of each other. Also if I try OR instead of AND, I also get a nil result.
Heres the code and printed output:
        width_shape = axlPathStart(PathList_W)
        new_W_shape = axlDBCreateShape(width_shape t "PACKAGE GEOMETRY/DISPLAY_TOP")  ; create first shape
        printf("new_W_shape: \n")
        print(new_W_shape)
        printf("\n")
        height_shape = axlPathStart(PathList_H)     ; returns r_path
        new_H_shape = axlDBCreateShape(height_shape t "PACKAGE GEOMETRY/DISPLAY_TOP")    ; create second shape
        printf("new_H_shape: \n")
        print(new_H_shape)
        printf("\n\n")
        poly_width  = axlPolyFromDB( car(new_W_shape) )     ; extract poly from the shapes
        poly_height = axlPolyFromDB( car(new_H_shape) )
        printf("poly_width: \n")
        print(poly_width)
        printf("\n")
        printf("height poly: \n")
        print(poly_height)
        printf("\n")
        mergedPolys = axlPolyOperation( car(axlPolyFromDB(poly_width)), car(axlPolyFromDB(poly_height)), 'AND )  ; perform logical AND, always returns nil
        printf("merged poly: \n")
        print(mergedPolys)
        printf("\n\n")
        shape = axlDBCreateShape(mergedPolys t "PACKAGE GEOMETRY/DISPLAY_BOTTOM" nil nil)     ;always fails
Here is the printed output in the console:
new_W_shape:
(dbid:000001E0F474F1F8 nil)
new_H_shape:
(dbid:000001E0F474F4C0 nil)
poly_width:
poly:000001E0F5B96ED8
height poly:
poly:000001E0F5B96EF0
merged poly:
nil
*WARNING* (axlPolyFromDB): Invalid database id argument - (poly:000001E0F5B977A0)
*WARNING* (axlPolyFromDB): Invalid database id argument - (poly:000001E0F5B977B8)
*WARNING* (axlDBCreateOpenShape): Object should be either an r_path or an o_polygon - (nil)
*WARNING* (axlDBCreateOpenShape): Not a floating point number! - nil
Any ideas what I'm doing wrong? Cheers and thankyou
  • HighFive
    EDIT-
    I found the solution. I wasnt extracting the poly from a "list" before submitting to the axlPolyOperation command. Here is the code that worked for me:
            mergedPolys = axlPolyOperation( car(poly_width ), car(poly_height), 'AND )
            shape = axlDBCreateShape(car(mergedPolys) t "PACKAGE GEOMETRY/DISPLAY_BOTTOM" nil nil)
