  3. Is there a way to convert a string into a SKILL command...
  • Subscribers 21
  • Views 10750
Is there a way to convert a string into a SKILL command?
David M Gonzales
David M Gonzales over 5 years ago
For example...
I have a string "axlFormSetField( GenerateForm_Handle "select_4" t )"
I would like to execute the string
  • HighFive
    HighFive over 5 years ago
    perhaps write it to a file and then execute the file?
  • David M Gonzales
    David M Gonzales over 5 years ago in reply to HighFive
    I am a new SKILL user. What command would execute the file?
  • DavidJHutchins
    DavidJHutchins over 5 years ago
    load( "filename")
  • David M Gonzales
    Thanks a lot! Works...
  • singletree
    singletree over 5 years ago
    evalstring("axlFormSetField( GenerateForm_Handle \"select_4\" t )")
