  3. Setting Allegro menu accessible settings with skill
  • Subscribers 19
  • Views 10842
HighFive
HighFive over 5 years ago
There are some "user settings" that I need to set for my script to produce the desired results. These all revolve around display settings, which I'm not sure how to set using function calls. I've looked through the user manual but havent seen anything. Here's the settings I need to modify:
  1. Setup->DesignParameters->Display:plated holes
  2. Setup->DesignParameters->Display:non-plated holes
  3. Setup->DesignParameters->Display:filled pads
  4. Setup->DesignParameters->Display->display net names(opengl only):pins
  5. File->Plot Setup->General: [all settings on this page ]
  6. File->Plot Setup->Windows: [all settings on this page ]
  7. File->Plot: [properties for the printer
Is this something that would be better done with the script interface? I wasnt sure if there were function calls to navigate the menu structure with skill or not. If this isnt something that can be done via function calls, what is the best way to run a script (.scr) from within a .il file?
Cheers and thankyou
  • DavidJHutchins
    DavidJHutchins over 5 years ago
    axlDBDisplayControl() controls the first 4 items, not sure about the printing stuff...
    (axlDBDisplayControl 'platedHolesEnable t)
    (axlDBDisplayControl 'nonPlatedHolesEnable t)
    (axlDBDisplayControl 'filledPadsEnable t)
    (axlDBDisplayControl 'displayNetNames t)
  • HighFive
    HighFive over 5 years ago in reply to DavidJHutchins
    As always, thank you for your excellent response David. You  are a wealth of information and I appreciate your contribution and assistance.
    I was able to get the printing stuff to work, by recording a .scr script, and then replaying the .scr file from within my .il file. Posting this here in case someone in the future has the same issue.
    Inside the skill .il file, calling the external script:
    axlShell("replay C:/Cadence/Setup/plot.scr")
    _____________________________________________________________________________________
    contents of plot.scr:
        generaledit
        plot setup
        setwindow form.fpfileplotsetup
        FORM fpfileplotsetup fpplotscale 1.00
        FORM fpfileplotsetup fpplotlineweight 1
        FORM fpfileplotsetup fpplotscaling YES
        FORM fpfileplotsetup fpplotautocenter YES
        FORM fpfileplotsetup fpplotmirror NO
        FORM fpfileplotsetup fpplotcolor YES
        ;FORM fpfileplotsetup fpplotsheetcontents YES
        FORM fpfileplotsetup fpplotscreencontents YES
        FORM fpfileplotsetup windows
        FORM fpfileplotsetup fpplotnonvectortext YES
        FORM fpfileplotsetup fpplotnonvectortextfont Calibri
        FORM fpfileplotsetup done
        setwindow pcb
        generaledit
        plotwint initialize "Foxit Reader PDF Printer"
        plotwint orientation 1
        plotwint papername "Letter"
        plotwint scale 100
        plotwint copies 1
        plotwint defaultsource 7
        plotwint printquality 600
        plotwint color 2
        plotwint duplex 1
        plotwint plottofile "plot.plottofile"
        plotwint execute
    This is a clean way to export a pdf of the current view. I'm nearly complete with the entire script, which emulates the "Label Tuning" function of the Allegro Productivity toolkit. I'll post the complete script in the forum when complete, so others may benefit.
    Cheers
