  3. Execute Regular Expression in Skill
  • Subscribers 19
  • Views 10674
HighFive
HighFive over 5 years ago
Hello friends,
Here's what I'm trying to accomplish, and where I've hit a roadblock: my skill program writes a .scr script, and then needs to execute the .scr file. The problem is, the .il file resides in C:\Cadence\Setup\, and the .scr file is writtent to whatever the current design directory is. So with a .BRD file open in Allegro, the .scr file is written to the same directory as the BRD file. This causes a problem- the .il skill file can't execute the .scr file. So I'm trying to parse the current design directory with axlCurrentDesign().
Which returns a string of the form: c:/users/poppy/documents/cadence/boardX/allegro/512_238.brd
Now I just need to trim the last part of the string off, everything after the last "/", such that the returned result is:
c:\users\poppy\documents\cadence\boardX\allegro\
Then I can use the above string as the directory file to write the .scr to. I tested by placing the file there manually and it works. So I need  to trim the path after the last "/".  I'm trying to do with regex, but can't get the pattern right. A patter that in theory works is:
I can't get it to work for me though. Can anyone help with the pattern entry? Then I will be calling:
rexCompile("\\\\([^/]*\\\\)$")
dir= rexReplace(dir, "", 0)
  • B Bruekers
    B Bruekers over 5 years ago +1
    Check the axlDMFileParts() function.
  • HighFive
    EDIT:
    Got it figured out. I guess I was overthinking it. I saw a bunch of threads with many "\\\\" to escape the backslash, so figured I needed that as well. What worked for me was:
    rexCompile("[^/]*$")
    dir = rexReplace(dir,"", 0)
  • B Bruekers
  • HighFive
    HighFive over 5 years ago in reply to B Bruekers
    Awesome that does exactly what I need it to! Thanks!
