  3. How to get the "fix" or "unfix" data of via with SKILL ...
  • Subscribers 20
  • Views 3893
How to get the "fix" or "unfix" data of via with SKILL ?
ichliebedich
ichliebedich over 5 years ago
Hi All,
I want to get the data that via has "fixed" property or not.
default via is "unfix" state,
but if I add the fix prop. I can see the "fixed" prop with "show element" command like below pic
regards,
  • luanvn81
    luanvn81 over 5 years ago
    Hi!
    You can check if a dbid is fixed or not by using axlDBIsFixed(o_dbid).  Value returned  is dbid if  it's fixed or nil if  object not fixed.
    Luan.
  • DavidJHutchins
    DavidJHutchins over 5 years ago
    try the following:
    when((((via->prop)->FIXED) == t)
      ;;your code here
  • ichliebedich
    Thank you! both codes were working well!
