  3. Launching executable Program through SKILL
  • Subscribers 19
  • Views 10154
ichliebedich
ichliebedich over 5 years ago
Hi all,
I'd like to launch programs through SKILL code on PCB environment
for example, if I want to launch the padstack, with which function can I launch the program padstack.exe?
(the path is, C:\Cadence\SPB_17.2\tools\bin\padstack_editor.exe )
regards,
  • ichliebedich
    I figured it out to run program with SKILL code used 'system' function
    if I want to run the program padstack, just put in the SKILL code below
    system("padstack_editor")
    but problem is only thing that Allegro PCB fall in pending till exit the padstack..
    so Does anyone know about running program with background? (two process parallelly)
  • DavidJHutchins
    DavidJHutchins over 5 years ago
     try
    skill '(system "START /B padstack_editor symbols/v_c20p10.pad")'
