  3. Does anyone know if there is a way to add "OK_UNASSIGNED_SHAPE...
  • Subscribers 18
  • Views 5505
Does anyone know if there is a way to add "OK_UNASSIGNED_SHAPE" using skill?
JS532
JS532 over 5 years ago
I'm using SKILL to generate some shapes using axlDBCreateRectangle(), converting it to dynamic using axlShapeChangeDynamicType(). I then want to add the "OK_UNASSIGNED_SHAPE" property to the shape. Does anyone know if there is a way to do this?
An example of the code:
shape = list(-1000.0:-1000.0 1000.0:1000.0)
sh1 = axlDBCreatRectangle(shape t "CONDUCTOR/TOP")
sh1 = axlShapeChangeDynamicType(car(sh1) t t)
when I look at properties now for using sh1->?? i can see there is a prop parameter but I'm not able to change it at all. It always reports nil. When I try to read the property of an existing shape that I know has the "OK_UNASSIGNED_SHAPE" property already defined on it I also only see nil for this property.
I understand there may be a way using axlDBAddProp() function but this doesn't seem to do anything either. I'm at a loss.
Any help is appreciated.
  • Ejlersen
    Ejlersen over 5 years ago
    Hi
    shape = list(-1.0:-1.0 1.0:1.0)
    sh1 = axlDBCreateRectangle(shape t "ETCH/TOP")
    res = axlDBAddProp(car(sh1) list("OK_UNASSIGNED_SHAPE" t))
    /Ole
  • JS532
    Hi Ejlersen,
    Thanks very much for sending me this.
    When I execute these steps in a skill window they appear to work. When I attempt to execute within a skill script however I get the following *Error* car:Can't take car of atom - "OK_UNASSIGNED_SHAPE"
    Here's the exact code I'm trying to accomplish:
    dShape = list( -1000.0:-1000.0 1000.0:1000.0 )
    sh1 = axlDBCreateRectangle(dShape t lyr)
    sh1 = axlShapeChangeDynamicType(car(sh1) t t )
    sh1 = car(axlShapeChangeDynamicType(sh1 nil t ))
    When running each line from the skill editor everything works correctly. It's only when I attempt to run inside a skill script that it has this error
