  3. Select Pin TextBlock with SKILL
  • Subscribers 19
  • Views 11351
Eric Jordan
Eric Jordan over 5 years ago
I am trying to find all the pin number textblocks and change the textblock to a specific number.
When I have a symbol selected, I can see each pin, but there is no textBlock property on the pins.
If I use one of the select functions and select the pin text, it's parent is a pin.
What's the correct way to get the textBlock of a specific pin on a symbol?
Here's some code I've tried:
When using skill to manually select a pin number (text as the search filter):
axlSetFindFilter(?enabled list("noall", "text") ?onButtons list("noall", "text"))
axlSingleSelectPoint()
; Manually Select Pin Number
pn = car(axlGetSelSet())
pn->objType
OUTPUT
"text"
pn->?
OUTPUT
(parentGroups justify isMirrored objType parent
    rotation mirrorType textBlock text xy
    readOnly bBox layer prop
pn->parent->objType
OUTPUT
"pin"
pn->parent->?
(fixedByTestPoint parentGroups pads definition parent
    relRotation relxy rotation mirrorType startEnd
    readOnly prop functionPins component testPoint
    isThrough isMirrored isMech isExploded branch
    net bBox xy number name
    objType use bondpad
What I'd expect from the last output would be some way to access the "text" object on the pin
  • B Bruekers
    B Bruekers over 5 years ago
    Use axlDBGetAttachedText(pin)   where pin is the dbID of the pin.
  • Eric Jordan
    Eric Jordan over 5 years ago in reply to B Bruekers
    I tried this and it does not work. When I use axlDBGetAttachedText on a pin, I do get a DBID, but it has no properties. When I pass it to axlDBChangeText I get the following error: *WARNING* (axlDBChangeText): Require a text dbid, dbid:000001AA61EC6C00
    Thanks for the suggestion though - any other ideas?
  • B Bruekers
    B Bruekers over 5 years ago in reply to Eric Jordan
    What inside id->objType?
    This should work :
    txtID = car(axlDBGetAttachedText(pinID))
    axlDBChangeText(txtID "a" 1)
  • Eric Jordan
    So the difference between the two is using car on the axlDBGetAttachedText, I missed that the function returns a list. It now works- I get a text object.
    Thanks!
