  3. is there a skill code which grabs a text string from an...
  • Subscribers 19
  • Views 10513
is there a skill code which grabs a text string from an external file and attaches this as user defined property value to an object in allegro?
papanna
papanna over 5 years ago
I am looking for a  skill code which grabs a particular text string from an external text file and attaches this as user defined property value to an object in allegro.
venu
  • EvanShultz
    EvanShultz over 5 years ago
    Sure.
    I'll leave the reading of the text file to you, but there are plenty of examples around. You can start with looking at subfolders of $CDS_ROOT\share\pcb\examples\skill.
    axlDBAddProp() will add the property to the object, and you will likely need to use axlDBCreatePropDictEntry() as well.
