  3. Hitting ENTER vs. TAB in a form field
  • Subscribers 19
  • Views 10472
David M Gonzales
David M Gonzales over 5 years ago
I have a STRFILLIN field in my form.
When I input text manually and hit TAB or click the mouse to a different field, there is no issue.
When I input text manually and hit ENTER, the SKILL script exits.
Is there a way to make ENTER the same as TAB?
David
  • B Bruekers
    B Bruekers over 5 years ago
    Perhaps you can try to set the default button to a different button on your form, or just disable it.
    See axlFormDefaultButton()
  • David M Gonzales
    Thanks a lot. Exactly what I needed. I also saw that you can define this in the form as well. In a colleague's script, he does not use either of these methods, yet ENTER is the same as TAB. just curious...
