  3. Need help with axlGetMetalUsageForLayer
  • Subscribers 20
  • Views 9836
luanvn81
luanvn81 over 5 years ago
Hi All!
I have tried to test axlGetMetalUsageForLayer() function on my allegro designer 17.2 but not supported. I want  ask  if is there any way to run that function on allegro. Or  is there an other way to caculate copper density on an area?
Thank.
 Luan.
  • DavidJHutchins
    DavidJHutchins over 5 years ago
    it works for me with allegro 17.4 S014 Windows SPB 64-bit Edition:
    skill 'setq data (axlGetMetalUsageForLayer list("ETCH/BOTTOM" "VIA CLASS/BOTTOM" "PIN/BOTTOM") list(list(-1150.35 408.77) list(-783.53 755.50)) t)'
    metalUsageData@0x79c9862170
    skill 'axlMsgPut("unit %s area %f percent %f" data->areaUnits data->metalArea data->percentMetalCoverage)'
    unit sq in area 0.127187 percent 100.000000
  • luanvn81
    luanvn81 over 5 years ago in reply to DavidJHutchins
    Hi David!
     Thank you for your reply.  I will try to test on allegro 17.4 as your advice.
    Best regards,
    Luan.
