  3. Use the fonction STRFILLIN.
  • Subscribers 20
  • Views 8726
Guillaume LG
Guillaume LG over 5 years ago
I would like to get a value that is entered on a STRFILLIN field, to impose this name on the IPC output file, but I’m stuck
       ("genipc"
        nameFileScript="geipcexecScript.txt"
        myFile=outfile(nameFileScript "w")
        fprintf(myFile "setwindow pcb\n")
        fprintf(myFile "ipc356 out\n")
        fprintf(myFile "setwindow form.ipc356\n")
        setq( ipc356file strcat("FORM ipc356 outfilename " getWorkingDir() "/"axlFormGetField(fw "numciBox")""))
        fprintf(myFile "%s\n" ipc356file)
        fprintf(myFile "FORM ipc356 version IPC-D-356A\n")
        close(myFile)
        scbedReplayScript(nameFileScript)
         deleteFile(nameFileScript)
        t)
            ; ------  champ numci
            fprintf(myPort "FIELD numciBox\n")
            fprintf(myPort "FLOC 52 52 \n")
            fprintf(myPort "STRFILLIN 8 6\n")
            fprintf(myPort "ENDFIELD\n")
Thanks for you help
  • DavidJHutchins
    DavidJHutchins over 5 years ago
    I would replace
    with
    (axlUIPrompt "Output File Name:" )
  • B Bruekers
    B Bruekers over 5 years ago
    Replace the 'setq' and fprintf  line with a single line like this:
    fprintf(myFile "FORM ipc356 outfilename \"%s/%s\"\n" getWorkingDir() axlFormGetField(fw "numciBox"))
    That should work.
