  3. How to see "Edit Via List" in Constraint Manager by command...
  • Subscribers 19
  • Views 4401
How to see "Edit Via List" in Constraint Manager by command or running specific SKILL function
ichliebedich
ichliebedich over 5 years ago
Hi All.
I want to see "Edit Via List" window (see below) by command or by SKILL function directly
although I tried to find out the command inside of Constraint Manager, I couldn't find it on command log window.
I just want to display current via stacks to user
regard
regard
  • B Bruekers
    B Bruekers over 5 years ago
    If it is only about which vias are defined then you can use axlCnsGetViaList()
  • ichliebedich
    ichliebedich over 5 years ago in reply to B Bruekers
    thank you, but I want to display the via lists which are user use. that window display the via lists and graphic as well
