  3. Rename subclass with SKILL
  • Replies 7
  • Subscribers 19
  • Views 11898
mir0mik
mir0mik over 5 years ago
Could someone help me, give me some pointers on how to rename user-defined subclass by SKILL?
I know how to add/remove subclasses by SKILL, but I can not figure out how to rename them (it is possible to rename them "manualy" so I suppose it is also possible by SKILL).
Thanks!
Miro
  • B Bruekers
    B Bruekers over 5 years ago
    If you have 17.4 then you can use axlLayerRenameNonConductor().
    If <17.4 then you need to do this with a script file (calling 'define subclass' and rename the subclass)
  • mir0mik
    mir0mik over 5 years ago in reply to B Bruekers
    Hi B Bruekers,
    Thanks for super fast reply!
    I had SKILL reference from Jun 2020 where axlLayerRenameNonConductor() doesn't exist so I updated to December 2020 :)
    I have 17.4 but unfortunately, I coding this for 17.2... so the second option could you please give more info about this approach?
    Do you mean axlShell( "define subclass") and I don't know how then rename the subclass by SKILL.
    Thanks!
  • B Bruekers
    B Bruekers over 5 years ago in reply to mir0mik
    Hi,  something like this:
    renameSc("MANUFACTURING"  "new_subclass" "test123")
    defun( renameSc (class scFrom scTo)
        let( (file p)
            axlLayerCreateNonConductor( strcat(class "/" scFrom))
            file = "./tmp.scr"
            p = outfile(file "w")
            fprintf(p "setwindow pcb\n")
            fprintf(p "trapsize 0\n")
            fprintf(p "generaledit\n")
            fprintf(p "define subclass\n")
            fprintf(p "setwindow form.subclass\n")
            fprintf(p "FORM subclass %s pick\n" class)
            fprintf(p "setwindow form.subclass_nonetch\n")
            fprintf(p "FORM subclass_nonetch %s rename %s\n" scFrom scTo)
            fprintf(p "FORM subclass done\n")
            fprintf(p "generaledit")
            close(p)
            axlShell(lsprintf("replay  %L" file))
  • mir0mik
    I've tried tried, but it doesn't work:
    axlShell( sprintf( nil "define subclass\nsetwindow form.subclass\nFORM subclass board_geometry pick\nsetwindow form.subclass_nonetch\nFORM subclass_nonetch %s rename %s\nsetwindow form.subclass\nFORM subclass done" "ncroute_path" "NEW NAME"))
    I'm going to look at your code and test it... I suppose this will not run on background (not blinking the subclasses menu)... right?
  • mir0mik
    So tested, your code works (there are some issues with spaces - script replace " " with "_" so "BOARD GEOMETRY" need to be "BOARD_GEOMTERY" for the script part, but that's OK).
    I'm a little bit disappointed that by CADENCE that such essential function is not present in SKILL for 17.2... If I would work on some quick SKILL code it would be OK, but I want to integrate this to something else (bigger) and I really don't like the fact that it is "just" script. But, thanks, now I know there is no command for this...
    What do you think about this, would this be usable?
    - create new "subclass"
    - find out what objects are members of the "old" subclass
    - change current subclass for all objects from "old" to "new" subclass
    - once the "old" subclass is empty it can be deleted
    I'm not fully satisfied with this, but it would run on the background (no flashing windows)...
