  3. FORM - ABORT (doneState == 3) IGNORES axlUIYesNo() - BUG...
  • Subscribers 18
  • Views 3924
FORM - ABORT (doneState == 3) IGNORES axlUIYesNo() - BUG?
mir0mik
mir0mik over 5 years ago
I've noticed a strange behaviour of the SKILL form...
See the short sample code - when you run this code and you close the form with [X] it will ignore the axlUIYesNo()... (see the callBack function > doneState == 3 section it should show Yes/No then Confirm)
Is this a bug or did I something wrong?
I also noticed when I removed the FIELD line from the form definition it works correctly... If I add any "action" field (button/fillin) into the form it will ignore the axlUIYesNo()...
Miro
defvar( www_formBugs "
FILE_TYPE=FORM_DEFN VERSION=2 \n
FORM FIXEDFIELDORDER \n
FIXED \n
PORT 42 40 \n
HEADER \"FORM BUGS DEMONSTRATOR\" \n
TILE \n
GROUP \"GROUP BOX\" \n FLOC 1 1 \n FSIZE 40 5 \n
TEXT \"CLOSE THE FORM WITH [X]\" FLOC 3 3\n ENDTEXT\n
ENDGROUP \n
FIELD www_formButton_QQQ \n FLOC 1 8 \n MENUBUTTON \"BUTTON\" 2 2 \n ENDFIELD \n
ENDTILE \n
ENDFORM \n
defun( www_formBugsCallBack ( www_formBugsCurrentAction)
when( www_formBugsCurrentAction -> doneState == 3
axlUIYesNo( "THIS IS AUTOMATICALLY SKIPED")
axlUIConfirm( "THIS WILL BE SHOWN ALWAYS")
when( www_formBugsCurrentAction -> curField == "www_formButton_QQQ"
axlUIConfirm( "BUTTON PRESSED")
www_formID = axlFormCreate( gensym() list( "FORM BUGs" list( www_formBugs)) nil 'www_formBugsCallBack t)
axlFormDisplay( www_formID)
  • mir0mik
    I've just tested it in 17.4 it works ok there, in 17.2 is not...
