  3. Force axlDBCreateShape() to not define a shape as a rectangle...
  • Subscribers 19
  • Views 10832
Force axlDBCreateShape() to not define a shape as a rectangle?
mstaub
mstaub over 5 years ago
Does anyone know a way to force the function axlDBCreateShape() to NOT define a shape as a rectangle when the o_polygon/r_path coordinates just happen to form a rectangle? For example I am using axlDBCreateShape() to create shapes in a design. In instances where the shape is rectangular, this function now defines the shape as a rectangle (as seen using shape->isRect or 'FILLED RECTANGLE' when using show element). When I draw this exact same shape using "Shape Add", the shape is always defined as a shape (nil for shape->isRect or 'SHAPE' when using show element).
The reason I don't want it to be defined as a rectangle is because I am later trying to modify the shape using axlDBOpenShape(). If the new shape outline is not a rectangle, this function won't modify the shape outline and return nil.
  • mstaub
    mstaub over 5 years ago +1
    ...And 10 minutes after posting this I found the solution. When looking at the documentation for axlDBCreateCloseShape(o_shape [g_forceShape]) I noticed it had the following parameter and description…
  • Grungy Remnant
    Grungy Remnant over 5 years ago in reply to mstaub +1
    Thanks for the solution update. I was having the same issue. :)
  • mstaub
    When looking at the documentation for axlDBCreateCloseShape(o_shape [g_forceShape]) I noticed it had the following parameter and description:
    g_forceShape
    By default, Allegro creates a rectangle in its database when an outline is a rectangle. This is for performance and space reasons. To override this behavior, pass the argument value as t when closing a shape.
    My guess is that since axlDBCreateShape()  is essentially a wrapper for axlDBCreateOpenShape() and axlDBCreateCloseShape() with no way to set g_forceShape, it's causing my shapes to be defined as rectangles. I have since changed my code to use axlDBCreateOpenShape() and axlDBCreateCloseShape() and set g_forceShape to 't' rather than using axlDBCreateShape() and everything is working as expected now!
  • Grungy Remnant
