  3. SKILL file ( .il) quit Function with error message popup...
  • Subscribers 19
  • Views 10142
SKILL file ( .il) quit Function with error message popup window
ichliebedich
ichliebedich over 5 years ago
Hi All
I want to quit SKILL file ( xxx.il ) immediately in Allegro if SKILL is not satisfied condition.
is there some exit function with error message popup window?
regard
  • B Bruekers
    B Bruekers over 5 years ago
    error("hello") creates an error and the execution of the remaining SKILL code is immediately terminated.  It does not generate a pop-up, but an error message in the command line.
    Use unwindProtect() if you want to run a function and what ever happens in that function, you always call a final function.
    unwindProtect(main_function() cleanup_Function() )
