  3. Expand a Polygon along one dimension only with SKILL
  • Subscribers 19
  • Views 11701
markmalin
markmalin over 5 years ago
I have a polygon with a given bounding box.  I want to take that polygon and create a new one, but have the X dimension 10% wider.
I'm somewhat new to SKILL, so bear with me.  I understand how I can get access to the given polygon object from the database, and I understand that there is a "bbox" list defining the bounding box.  If I calculate the width in X to be some number of user units, I want to add them like so:
xDistance = sqrt(caar(myPolygon->bBox) - cadr(myPolygon->bBox))
xDistance = expt(xDistance 2)
xExpandDist = xDistance * (0.1)
Now I want to expand the myPolygon->bBox "xExpandDist/2" to the left (i.e. on the X axis), and "xExpandDist/2" to the right (i.e. on the X axis).
I understand that a polygon has a bounding box, I can get the X,Y coordinates for the bbox, I know how much I want to expand it, but can I simply assign a new value to it?  In other words, in pseudo code:
myPolygon's bbox lower left x value = myPolygon's bbox lower left x value - xExpandDist
myPolygon's bbox upper right x value = myPolygon's bbox upper right x value + xExpandDist
How do I do this?  How do I change the X coordinates of the bounding box?
Mark
  • DE202408202727
    DE202408202727 over 5 years ago +1
    You need to take the vertices from the polygon and add your delta x to those. This code should help you: defun( DE_polyVertsToPath (poly @key (expandx 0), (expandy 0) (width 0)) let((dx, dy, midPoly…
  • DavidJHutchins
    DavidJHutchins over 5 years ago
    No, the bounding box is calculated from the min/max values of the segments
    To modify the X dimensions you will need to recalculate the X coordinates of the min & max locations, then rebuild the shape
  • DE202408202727
    let((dx, dy, midPoly, verts, pt1, pt2, rpath, radius, cw)
    dx = expandx / 2.0
    dy = expandy / 2.0
    midPoly = axlMidPointLine(poly ->bBox)
    verts = poly ->vertices
    pt1 = DE_polyVertsToPath_expandPt(caar(verts), dx, dy, midPoly)
    rpath = axlPathStart(list(pt1), width)
    foreach(vert, car(tconc(lconc(nil, cdr(verts)), car(verts)))
    pt2 = DE_polyVertsToPath_expandPt(car(vert), dx, dy, midPoly)
    unless(axlGeoPointsEqual(pt1, pt2)
    radius = cadr(vert)
    if(zerop(radius)
    then axlPathLine(rpath, width, pt2)
    else cw = plusp((cadr(pt2) - cadr(pt1)) * radius), axlPathArcRadius(rpath, width, pt2, cw, nil, abs(radius))
    pt1 = pt2
    ); foreach vert
    rpath
    defun( DE_polyVertsToPath_expandPt (pt, dx, dy, midPt)
    list(
    if(car(pt) < car(midPt) then car(pt) - dx else car(pt) + dx)
    if(cadr(pt) < cadr(midPt) then cadr(pt) - dy else cadr(pt) + dy)
  • markmalin
    markmalin over 5 years ago in reply to DE202408202727
    Thanks.  This is helpful.  It wasn't clear from the documentation how to either modify and existing shape or how to re-create/create one.  I'll look closely at the example you posted.  Thanks!  Mark
