  3. How to use quotes on skill command on Windows
  • Subscribers 19
  • Views 9930
ANSYS
ANSYS over 5 years ago
I'm creating a menu to handle and export some results to Excel and I'm having troubles to use paths with spaces. I tried to use the "\"" approach but it still doesn't work for the arguments. In my case I'm trying to open a csv file like below:
csvinput="C:\\temp\\tmp space\\mydata.csv"
path=axlGetVariable("CURRENT_OFFICE_VERSION")
cmdOpenCSV=strcat( "\"" path "\\EXCEL.EXE" "\" \"" csvinput "\"" )
cid = ipcBatchProcess(cmdOpenCSV "" "c:\\temp\\skill_log.txt")
If I place mydata.csv on a folder without spaces, it works. Also, strangely enough the "\"" worked for excel's path as it also has white spaces. Could someone please comment on that?
Thanks in advance.
  • B Bruekers
    B Bruekers over 5 years ago +1
    You need to 'double' escape the csv path so it creates a \"<csv file>\" string which then appears as "<csv file>" is the actual command line. cmdOpenCSV=strcat( "\"" path "\\EXCEL.EXE" "\" \\\"" csvinput…
  • B Bruekers
    cmdOpenCSV=strcat( "\"" path "\\EXCEL.EXE" "\" \\\"" csvinput "\\\"" )
