  3. How to find dbid of all component inside a circle?
  • Subscribers 20
  • Views 10572
solene D
solene D over 5 years ago
I am new to skill and I need help please.
I created a circle using axlPathStartCircle.
And now I would like to find the dbid of all component inside this circle (
even components that are not entirely in it).
But I can't find a function that allows me to do this.
Can anyone help me please?
Thank's
PS:
something else strange but unrelated: for circles, when I search for their bBox with axlGeoGetBBox, I get the center and a point on the edge of the circle. Is this normal?
  • DavidJHutchins
    DavidJHutchins over 5 years ago
    eDave suggested a solution for this 8 years ago, search for 'Circle area selection?'
  • B Bruekers
    B Bruekers over 5 years ago
    If you are using 17.2.050 or newer then there is a select by polygon function.
    Something like this:
    axlSetFindFilter(?enabled '("noall" "shapes") ?onButtons '("shapes"))
    when(axlSelect(?prompt "select shape")
        sel = car(axlGetSelSet())
        poly = car(axlPolyFromDB(sel))
        axlClearSelSet()
        axlSetFindFilter(?enabled '("noall" "pins" "vias") ?onButtons '("pins" "vias"))
        axlAddSelectPoly(poly t)  ;t = include voids
        l_sel = axlGetSelSet()
        axlClearSelSet()
        pprintln(l_sel~>objType)
        axlHighlightObject(l_sel t)
    If you change the first find filter to lines/line segs then you should be able to select the circle and get all pins and vias (other find filter) inside this circle.
  • solene D
    solene D over 5 years ago in reply to DavidJHutchins
    Thank you
  • solene D
    solene D over 5 years ago in reply to B Bruekers
    Thank you very much
