  3. Parse a String with SKILL
  • Subscribers 20
  • Views 12951
leto
leto over 5 years ago
Hello All,
I have a string  C200_2
I would like break it up to separate alphabets, numbers & special characters
The results should be a list ("C" "200" "_" "2")
Is there a build in function of SKILL to do this?
If not, how should I do this manually?
Thanks All
  • Kirti Sikri
    Kirti Sikri over 5 years ago
    You can use parseString as shown in the code below
    parseString("C200_2" "")
    About parseString
    parseString breaks a string into a list of substrings with specified break characters, which are indicated by an optional second argument.
    Space is the default break character
    Ex: parseString( "Now is the time" ) => ("Now" "is" "the" "time")
    From COS
    parseString
    parseString(
    S_string [ S_breakCharacters ] [ g_insertEmptyString ] ) => l_strings
    Description
    Breaks a string into a list of substrings with break characters.
    Returns the contents of S_string broken up into a list of words. If the optional second argument, S_breakCharacters, is not specified, the white space characters, \t\f\r\n\v, are used as the default. If the third optional argument g_insertEmptyString is provided, insert (“ “) into the result list at each occurrence of S_breakCharacters. It generates the list of strings so that if the S_breakCharacters has a single character then the generated string is:
    buildString( parseString( string delimiter t) delimiter)
    A sequence of break characters in S_string is treated as a single break character. By this rule, two spaces or even a tab followed by a space is the same as a single space. If this rule were not imposed, successive break characters would cause null strings to be inserted into the output list.
    If S_breakCharacters is a null string, S_string is broken up into characters. You can think of this as inserting a null break character after each character in S_string.
    No special significance is given to punctuation characters, so the “words” returned by parseString might not be grammatically correct.
    Arguments
    S_string
    String to be parsed.
    S_breakCharacters
    List of individual break characters.
    Value Returned
    l_strings
    List of strings parsed from S_string.
    Example
    parseString( "prepend" "e" )       => ("pr" "p" "nd" )
    e is the break character.
    parseString( "feed" "e")           => ("f" "d")
    parseString( "~/exp/test.il" "./") => ("~" "exp" "test" "il")
    Both . and / are break characters.
    parseString( "abc de" "")          => ("a" "b" "c" " " "d" "e")
    The single space between c and d contributes " " in the return result.
    parseString( "-abc-def--ghi-" "-" )
    => ("abc"  "def"  "ghi")
    Splits the string at each occurrence of the delimiter character "-".
    parseString( "-abc-def--ghi-" "-" t )
    => (""  "abc"  "def"  ""  "ghi"  "")
    Inserts an empty string at each occurrence of the delimiter character "-".
  • B Bruekers
    B Bruekers over 5 years ago
    If you know the format of your input string then you can make a regular expression to 'extract' the values.
    pcre = pcreCompile("(\\w)(\\d+)_(\\d+)")
    pcreExecute(pcre "C200_2")
    pcreSubstitute("\\1")
    pcreSubstitute("\\2")
    pcreSubstitute("\\3")
    Alternatively, there is an undocumented function which seems to do something that you need:
    _alphaNumBreakIntoChunks("C200_2")
    ("C" "200" "_" "2")
  • leto
    leto over 5 years ago in reply to B Bruekers
    Thanks Bruekers!!
    That is exactly what I needed :D
