  3. Getting values by form CHECKLIST
  • Subscribers 19
  • Views 12059
vimaldevlpr
vimaldevlpr over 5 years ago
hi,
Any body help me out this kind of loop CHECKLIST case.
In input selected corresponding part value want to print any one please help me out from this.
Input -        Output -
        aaa ccc
Code:
  list1 = '("aaa" "bbb" "ccc" "ddd")
  datainp = 5
  foreach(listlp list1
   adata = sprintf(nil, "TEXT \"%s\"\n", listlp)
   fprintf(backform adata)
   adt = sprintf(nil, "TLOC 5 %d\n", datainp)
   fprintf(backform adt)
   datainp = datainp + 5
   fprintf(backform "ENDTEXT\n")
  datainp2 = 5
  foreach(listlp3 list1
   fprintf(backform "FIELD Checkdt\n")
   adt2 = sprintf(nil, "FLOC 25 %d\n", datainp2)
   fprintf(backform adt2)
   fprintf(backform "CHECKLIST \"Check\" \n")
   fprintf(backform "ENDFIELD\n")
   fprintf(backform "\n")
   datainp2 = datainp2 + 5
fprintf(backform "FIELD TOCHECK\n")
  fprintf(backform "FLOC 13 1\n")
  fprintf(backform "MENUBUTTON \"Checking\" 10 4\n")
(defun back_Action (backform)
 (case backform->curField
  ("TOCHECK"
   ("Checkdt"
    if(backform->curValue then
         ;Help me to get the corresponding value
 axlFormDisplay(backform)
  • vimaldevlpr
    vimaldevlpr over 5 years ago in reply to DavidJHutchins
    Hi david Kindly thanks for the reply.. By using button directly it returns nil
    Input -
    If I clicking bbb means need to return bbb.        output - bbb
    My code:
    (setq list1 list("aaa" "bbb" "ccc" "ddd"))
    (setq viamod_symform_file "viamod_sym.form")
    procedure(chk()
     createviamod_symform()
     viamod_symform_run()
    procedure(viamod_symform_run()
     let((viamod_symform)
      (viamod_symform = axlFormCreate(gensym() viamod_symform_file nil 'viamod_sym_Action t))
      axlFormDisplay(viamod_symform)
    procedure(createviamod_symform()
     let((viamod_symform datainp adata adt datainp2 adt2)
      (viamod_symform = outfile(viamod_symform_file "w"))
       fprintf(viamod_symform "FILE_TYPE=FORM_DEFN VERSION=2\n")
       fprintf(viamod_symform "FORM\n")
       fprintf(viamod_symform "FIXED\n")
       fprintf(viamod_symform "PORT 42 10\n")
       fprintf(viamod_symform "HEADER \"UI CHECK\"\n")
       fprintf(viamod_symform "\n")
       fprintf(viamod_symform "TILE\n")
       (datainp2 = 5)
        fprintf(viamod_symform "FIELD %s\n" listlp3)
        (adt2 = sprintf(nil "FLOC 15 %d\n" datainp2))
        fprintf(viamod_symform adt2)
        (adt3 = sprintf(nil "MENUBUTTON \"%s\" 10 4\n" listlp3))
        fprintf(viamod_symform adt3)
        fprintf(viamod_symform "ENDFIELD\n")
        (datainp2 = (datainp2 + 4))
       fprintf(viamod_symform "ENDTILE\n")
       fprintf(viamod_symform "ENDFORM\n")
       drain()
       close(viamod_symform)
    procedure(viamod_sym_Action(viamod_symform)
     sym_data = nil
      case((viamod_symform->curField)
        when(axlFormGetField(viamod_symform listlp3)
        print(listlp3)
        when(listlp3 push(listlp3 sym_data))
        ;print(" ")
        ;println(" ")
    sym_wrkng()
    procedure(sym_wrkng()
     print(sym_data)
