  3. Getting values by form CHECKLIST
  • Subscribers 19
  • Views 12058
vimaldevlpr
vimaldevlpr over 5 years ago
hi,
Any body help me out this kind of loop CHECKLIST case.
In input selected corresponding part value want to print any one please help me out from this.
Input -        Output -
        aaa ccc
Code:
  list1 = '("aaa" "bbb" "ccc" "ddd")
  datainp = 5
  foreach(listlp list1
   adata = sprintf(nil, "TEXT \"%s\"\n", listlp)
   fprintf(backform adata)
   adt = sprintf(nil, "TLOC 5 %d\n", datainp)
   fprintf(backform adt)
   datainp = datainp + 5
   fprintf(backform "ENDTEXT\n")
  datainp2 = 5
  foreach(listlp3 list1
   fprintf(backform "FIELD Checkdt\n")
   adt2 = sprintf(nil, "FLOC 25 %d\n", datainp2)
   fprintf(backform adt2)
   fprintf(backform "CHECKLIST \"Check\" \n")
   fprintf(backform "ENDFIELD\n")
   fprintf(backform "\n")
   datainp2 = datainp2 + 5
fprintf(backform "FIELD TOCHECK\n")
  fprintf(backform "FLOC 13 1\n")
  fprintf(backform "MENUBUTTON \"Checking\" 10 4\n")
(defun back_Action (backform)
 (case backform->curField
  ("TOCHECK"
   ("Checkdt"
    if(backform->curValue then
         ;Help me to get the corresponding value
 axlFormDisplay(backform)
  • DavidJHutchins
    DavidJHutchins over 5 years ago
    Try replacing:
    With the following:
       fprintf(backform "FIELD %s\n",listlp3)d
    And then replace:
      ("TOCHECK"
       ("Checkdt"
    With the following:
        axlFormSetField backform listlp3 nil)
    procedure(back_Action(backform)
            when( (axlFormGetField backfrom listlp3) print(listlp3))
            print(" ")
        println(" ")
  • vimaldevlpr
    vimaldevlpr over 5 years ago in reply to DavidJHutchins
    Hi David,
    Thanks for the reply I tried to replace your code but it shows me ERROR - E- *Error* eval: unbound variable - backfrom.
    I will attach edited code below can you please recorrect it.
    Code -
    (defun chk ()
     createbackform()
     backform()
    (defun backform ()
     backform=axlFormCreate( (gensym) backform_file nil 'back_Action t)
    (defun createbackform ()
     drain()
      backform_file = "back.form"
      backform = outfile(backform_file "w")
      fprintf(backform "FILE_TYPE=FORM_DEFN VERSION=2\n")
      fprintf(backform "FORM\n")
      fprintf(backform "FIXED\n")
      fprintf(backform "PORT 42 10\n")
      fprintf(backform "HEADER \"UI CHECK\"\n")
      fprintf(backform "TILE\n")
      datainp = 5
      datainp2 = 5
       fprintf(backform "FIELD %s\n", listlp3)
      ;fprintf(backform "FIELD Checkdt\n")
      ;fprintf(backform "FLOC 10 20 \n")
      ;fprintf(backform "CHECKLIST \"Check\" \n")
      ;fprintf(backform "ENDFIELD\n")
      fprintf(backform "ENDTILE\n")
      fprintf(backform "ENDFORM\n")
     close(backform)
      ("TOCHECK"
         (axlFormSetField backform listlp3 nil)
         when((axlFormGetField backfrom listlp3) print(listlp3))
         print(" ")
         println(" ")
  • DavidJHutchins
    try the modified code shown  below:
    (setq list1 list("aaa" "bbb" "ccc" "ddd"))
    (setq backform_file "back.form")
    procedure(chk()
    createbackform()
    backform_run()
    procedure(backform_run()
    let((backform)
    (backform = axlFormCreate(gensym() backform_file nil 'back_Action t))
    procedure(createbackform()
    let((backform datainp adata adt datainp2 adt2)
    (backform = outfile(backform_file "w"))
    (datainp = 5)
    (adata = sprintf(nil "TEXT \"%s\"\n" listlp))
    (adt = sprintf(nil "TLOC 5 %d\n" datainp))
    (datainp = (datainp + 5))
    (datainp2 = 5)
    fprintf(backform "FIELD %s\n" listlp3)
    (adt2 = sprintf(nil "FLOC 25 %d\n" datainp2))
    (datainp2 = (datainp2 + 5))
    drain()
    close(backform)
    case((backform->curField)
    ("TOCHECK"
    when(axlFormGetField(backform listlp3)
    print(listlp3)
    print(" ")
    println(" ")
  • vimaldevlpr
    Hi david thanks for the reply one last help please.
    I would like to get like this output shown below. for me it shows nil I will attach my code below can you please recorrect my code. please
    Input -        Output -
        aaa, 30.00
        ccc, 40.00
    code -
    (setq viamod_lyrform_file "viamod_lyr.form")
    procedure(chk_lyr()
    createviamod_lyrform()
    viamod_lyrform_run()
    procedure(viamod_lyrform_run()
    let((viamod_lyrform)
    (viamod_lyrform = axlFormCreate(gensym() viamod_lyrform_file nil 'viamod_lyr_Action t))
    axlFormDisplay(viamod_lyrform)
    procedure(createviamod_lyrform()
    let((viamod_lyrform datainp adata adt datainp2 adt2)
    (viamod_lyrform = outfile(viamod_lyrform_file "w"))
    fprintf(viamod_lyrform "FILE_TYPE=FORM_DEFN VERSION=2\n")
    fprintf(viamod_lyrform "FORM\n")
    fprintf(viamod_lyrform "FIXED\n")
    fprintf(viamod_lyrform "PORT 42 10\n")
    fprintf(viamod_lyrform "HEADER \"UI CHECK\"\n")
    fprintf(viamod_lyrform "\n")
    fprintf(viamod_lyrform "TILE\n")
    (datainp = 5)
    fprintf(viamod_lyrform adata)
    fprintf(viamod_lyrform adt)
    (datainp = (datainp + 2))
    fprintf(viamod_lyrform "ENDTEXT\n")
    (datainp2 = 5)
    fprintf(viamod_lyrform "FIELD %s\n" listlp3)
    fprintf(viamod_lyrform adt2)
    ;fprintf(viamod_lyrform "CHECKLIST \n")
    fprintf(viamod_lyrform "REALFILLIN 5 5\n")
    fprintf(viamod_lyrform "REALMIN 1.0\n")
    fprintf(viamod_lyrform "REALMAX 1000.000000\n")
    fprintf(viamod_lyrform "ENDFIELD\n")
    (datainp2 = (datainp2 + 2))
    fprintf(viamod_lyrform "FIELD TOCHECK\n")
    fprintf(viamod_lyrform "FLOC 13 1\n")
    fprintf(viamod_lyrform "MENUBUTTON \"Checking\" 10 4\n")
    fprintf(viamod_lyrform "ENDTILE\n")
    fprintf(viamod_lyrform "ENDFORM\n")
    drain()
    close(viamod_lyrform)
    procedure(viamod_lyr_Action(viamod_lyrform)
    sym_data = nil
    case((viamod_lyrform->curField)
    ("TOCHECK"
    when(axlFormGetField(viamod_lyrform listlp3)
     StubVal = viamod_lyrform->curValue
     finalrep = sprintf(nil, "%s,%L", listlp3, StubVal)
     print(finalrep)
     when(finalrep push(finalrep sym_data))
    ;print(" ")
    ;println(" ")
    sym_wrkng()
    procedure(sym_wrkng()
    print(sym_data)
  • DavidJHutchins
    try the modified code below:
    let((StubVal finalrep)
    ("TOCHECK"
    when((axlFormGetField viamod_lyrform listlp3)
    (StubVal = (axlFormGetField viamod_lyrform listlp3))
    (finalrep = sprintf(nil "%s,%L" listlp3 StubVal))
    ;print(finalrep)
    when(StubVal > 0.0
    ;push(finalrep sym_data)
    println(finalrep)
    (axlFormDisplay viamod_lyrform)
    ;sym_wrkng()
