  3. axlUIViewFileCreate not working for html file 17.4
  • Subscribers 17
  • Views 6065
HJerry
HJerry over 4 years ago
Hi all,
We have a program that creates a log file in html format, then opens it using axlUIViewFileCreate.
This works fine in 17.2, but now opens the file as a text document in 17.4.
I have allegro_html turned on and allegro_html_qt turned off.
Anyone else have this issue? If so, were you able to correct it?\
Jerry
  • HJerry
    Hi all, I found part of the issue in this thread from EvanShultz : 1378981#1378981
    <html>  needs to be on the first line of your HTML code.
    My only issue now is the table borders are missing.
    Here is the HTML code for the table:
    <style> table, td {border: 1px solid black; padding: 5px;}
    table#n01 th { border: 1px solid black; background-color:#FF9900; color: white; padding: 5px;} </style>
    <table id=n01> <tr> <th>Diff Pair Name</th> <th>Rule Used</th> <th>Obj 1 Loc</th> <th>Obj 2 Loc</th> <th># Plane RKO</th> <th># Signal RKO</th> <th>Layer : Voids</th> <th>Obj Type</th> </tr>
    <tr> <td>NA</td> <td>VOID_2SYM:CAP0402 = 40:shp-86x72-rndcorner:0:3:-1</td> <td>((3224.055 12072.56))</td> <td>((3224.055 12112.56))</td> <td>3</td> <td>0</td> <td>2-4</td> <td>symbol-PACKAGE,symbol-PACKAGE</td> </tr>
    </table>
    Jerry
