  3. error when trying to load plt file using axlDetailLoad
  • Subscribers 19
  • Views 9252
jruffsr
jruffsr over 4 years ago
I am trying to use the following skill code to load a plt file. This is to replace a script I was using in 16.6 and now trying to migrate to 17.4.
    (axlMsgPut "Turning on DRAWING_FORMAT/PS_OUTLINE")
    axlVisibleLayer("DRAWING FORMAT/PS_OUTLINE" t)
    (axlMsgPut "Generating Border script")
    file = "X:/conf_root/ABB/JMM/pcb/plot/pwbfabBorder.plt"
    (axlMsgPut "Found border file %L" file)
    axlDetailLoad(
        file
        -2400:-3600
        1.0
        0
        nil
This code shows a spinning icon but never completes and after 15 min exits with no data found on the indicated layer.
Any guidance on what could be wrong would be appreciated. Note: I am able to import this plt without any issues.
  • DavidJHutchins
    DavidJHutchins over 4 years ago
    I just output a plot file using axlDetailSave() & interactively using File>Export>IPF... ( which runs 'create plot )
    The first lines of the 2 files are not in the same format, the file from axlDetailSave has 4 entries, while the file from 'create plot' has 4 entries
    So axlDetailLoad() can not correctly read a file created by 'create plot', it outputs thousands of errors stating 'ERROR(SPMHMF-392): Cannot read the line data.'
