  3. error when trying to load plt file using axlDetailLoad
  • Subscribers 19
  • Views 9251
jruffsr
jruffsr over 4 years ago
I am trying to use the following skill code to load a plt file. This is to replace a script I was using in 16.6 and now trying to migrate to 17.4.
    (axlMsgPut "Turning on DRAWING_FORMAT/PS_OUTLINE")
    axlVisibleLayer("DRAWING FORMAT/PS_OUTLINE" t)
    (axlMsgPut "Generating Border script")
    file = "X:/conf_root/ABB/JMM/pcb/plot/pwbfabBorder.plt"
    (axlMsgPut "Found border file %L" file)
    axlDetailLoad(
        file
        -2400:-3600
        1.0
        0
        nil
This code shows a spinning icon but never completes and after 15 min exits with no data found on the indicated layer.
Any guidance on what could be wrong would be appreciated. Note: I am able to import this plt without any issues.
  • DavidJHutchins
    DavidJHutchins over 4 years ago
    I tried running a version of your skill code, but it didn't load the file that I manually loaded before running the skill code, below are the errors I got:
    \e (00:00:49) ERROR(SPMHMF-414): Unknown element type 39.
    \e (00:00:49) ERROR(SPMHMF-414): Unknown element type 46.
    \e (00:00:49) ERROR(SPMHMF-414): Unknown element type 221.
    \e (00:00:49) ERROR(SPMHMF-414): Unknown element type 26.
    \e (00:00:49) ERROR(SPMHMF-414): Unknown element type 71.
    \e (00:00:49) ERROR(SPMHMF-414): Unknown element type 0.
    \e (00:00:49) ERROR(SPMHMF-414): Unknown element type 9.
    \e (00:00:49) ERROR(SPMHMF-413): Error -3000269 while processing polygon data.
  • jruffsr
    jruffsr over 4 years ago in reply to DavidJHutchins
    thanks for checking. the fact that you also was able to load manually suggests a problem with axlDetailLoad. I have contacted support on this and i am now waiting for their response.
  • DavidJHutchins
    I just opened a support case for this...
    Update 46571304 axlDetailLoad fails to load file that works fine via File>Import>IPF (load plot)
  • DavidJHutchins
    DavidJHutchins over 4 years ago in reply to DavidJHutchins
    Further testing shows that it works if you save the data with axlDetailSave first ( which seems weird... )
    \i (00:11:19) set telskill
    \i (00:11:25) skill 'axlSetFindFilter(?enabled list("noall" "shapes" "text" ) ?onButtons list("noall" "shapes" "text"))'
    (00:11:25) t
    \i (00:11:30) skill axlAddSelectBox()
    \i (00:11:35) pick 229.62 762.24
    \t (00:11:35) last pick: 229.62 762.24
    \i (00:11:36) pick 690.94 587.28
    \t (00:11:36) last pick: 690.94 587.28
    (00:11:36) t
    \i (00:11:55) skill data=axlGetSelSet()
    (00:11:55) (dbid:0000009B30599BA0 dbid:0000009B3059DDF8 dbid:0000009B3059F108 dbid:0000009B30599DD0 dbid:0000009B3059A000
    (00:11:55) dbid:0000009B305A1050 dbid:0000009B30599928 dbid:0000009B305999D0
    (00:11:55) )
    \i (00:12:29) skill ' axlDetailSave( "logo" list( list(221 580) list(680 770)) data nil)'
    (00:12:29) t
    \i (00:13:08) setwindow form.mini
    \i (00:13:08) FORM mini class 'BOARD GEOMETRY'
    \i (00:13:16) FORM mini subclass SILKSCREEN_TOP
    \i (00:13:17) setwindow pcb
    \i (00:13:17) zoom out 1
    \i (00:14:47) skill 'axlDetailLoad( "logo" 1200:555 1.0 0 nil)'
    (00:14:48) t
  • jruffsr
    Thanks for the info. I an not sure I understand what is going on. it looks like you generate a plt file and then you can import previously saved plt file.  The file was saved in 16.6, do you believe I need to save it out in 17.4 to work?
    Thank you again for this information.
