  3. axlRunBatchDBProgram to run a report in 17.4
  • Subscribers 18
  • Views 7225
HJerry
HJerry over 4 years ago
Hi all,
We are using the following syntax, in 17.2, to create different reports and it works fine.
sprintf(cmd, "report -v sum \"%s\" summary.rpt", axlGetDrawingName() )
axlRunBatchDBProgram("summary report" cmd ?noLogview t ?noExitMsgs t)
When I try the same code in 17.4 it does no recognize axlGetDrawingName() as the for the design name.
I also tried axlCurrentDesign() and that did not work in 17.4, either.
Any ideas would be appreciated.
Jerry
  • DavidJHutchins
    DavidJHutchins over 4 years ago
    I am running allegro 17.4 S020 Windows SPB 64-bit Edition
    I don't have any issues with core commands not working correctly:
    \i (01:10:48) skill axlGetDrawingName()
    (01:10:48) "D:/SPB_Data/xxxx/Eagle_Fountain/eagle_fountain_sfp_dp_lp_110821c.brd"
    \i (01:11:07) skill axlCurrentDesign()
    (01:11:07) "eagle_fountain_sfp_dp_lp_110821c"
    \i (01:11:58) skill
    \i (01:12:22) skill 'sprintf(cmd, "report -v sum `\"%s`\" summary.rpt", axlGetDrawingName() )'
    (01:12:22) "report -v sum \"D:/SPB_Data/xxxx/Eagle_Fountain/eagle_fountain_sfp_dp_lp_110821c.brd\" summary.rpt"
    however the axlRunBatchDBProgram command doesn't appear to have the correct syntax:
    \i (01:12:49) skill 'axlRunBatchDBProgram("summary report" cmd ?noLogview t ?noExitMsgs t)'
    \e (01:12:49) Batch command line string missing "%s" placeholder for design name; command line must be formatted properly.
    \i (01:13:00) fillin confirm
    (01:13:00) -1
  • HJerry
    I found the issue. In 17.4 you need to escape the %s with a % when doing a sprintf. So:
    sprintf(cmd, "report -v sum \"%%s\" summary.rpt" axlGetDrawingName())
    Jerry
