  3. Datum Dimension by skill
  • Subscribers 21
  • Views 6319
vimaldevlpr
vimaldevlpr over 4 years ago
Hi
Is any way to do datum dimension measuring and placing in corner of brd file using cadence skill program if it possible please guide me to do.
  • DavidJHutchins
    DavidJHutchins over 4 years ago
    You can't do this directly using skill since there are no direct skill commands for doing this & the dimensioning commands appear to block skill commands
    I was able to do this by having the skill code write a script file which it replays after generating it...
    Example script file segment for the design cds_routed.brd shown below:
    version 17.4
    setwindow pcb
    generaledit
    dimension edit
    prepopup 0 0
    pop dyn_option_select @:@Parameters
    setwindow form.draft_parms
    FORM draft_parms text
    FORM draft_parms align_text YES
    FORM draft_parms done
    setwindow pcb
    color192
    QtSignal CVDLayerContainer CVDVisibilityOff clicked
    QtSignal CVDLayerSplitter CVDLayersTree itemSelectionChanged "Drawing format"
    QtSignal CVDLayerTable CVDLayerTableDelegate clickedBox "Drawing_Origin" Drawing 1
    QtSignal CVDLayerSplitter CVDLayerTable dataChanged 1 0
    QtSignal CVDLayerSplitter CVDLayerTable selectionChanged
    QtSignal ColorVisibilityDialog CVDOkButton clicked
    setwindow pcb
    generaledit
    dimension edit
    setwindow pcb
    setwindow form.mini
    FORM mini datum_axis BOTH
    setwindow pcb
    prepopup 0 0
    pop dyn_option_select '@:@Datum dimension'
    pick 0 0
    pick 0 -650.000000
    pick 0 -1050.000000
    prepopup 0 0
    next
    pick -650.000000 0
    pick -1050.000000 0
    prepopup 0 0
    done
    setwindow pcb
    color192
    QtSignal CVDLayerSplitter CVDLayersTree itemSelectionChanged Geometry
    QtSignal CVDLayerTable VertHeader clickedCheckBox Outline 1
    QtSignal CVDLayerSplitter CVDLayerTable dataChanged 17 0
    QtSignal CVDLayerTable VertHeader clickedCheckBox "Design_Outline" 1
    QtSignal CVDLayerSplitter CVDLayerTable dataChanged 8 0
    setwindow pcb
    color192
    QtSignal CVDLayerTable VertHeader clickedCheckBox Dimension 0
    QtSignal CVDLayerSplitter CVDLayerTable dataChanged 11 0
    QtSignal CVDLayerTable VertHeader clickedCheckBox Dimension 1
    setwindow pcb
    generaledit
    dimension edit
    prepopup 0 0
    setwindow form.find
    FORM find all_off
    FORM find other_segs YES
    setwindow pcb
    setwindow form.mini
    FORM mini datum_axis X
    setwindow pcb
    echo X
    echo -150.000000 -100.000000
    pick -150.000000 -100.000000
    pick -150.000000 -650.000000
    pick -150.000000 -1050.000000
    prepopup 0 0
    next
    echo -100.000000 150.000000
    pick -100.000000 150.000000
    pick -100.000000 -650.000000
    pick -100.000000 -1050.000000
    prepopup 0 0
    next
    echo 150.000000 150.000000
    pick 150.000000 150.000000
    pick 150.000000 -650.000000
    pick 150.000000 -1050.000000
    prepopup 0 0
    next
