  3. SKILL access to Allegro Export PDF parameters?
  • Subscribers 19
  • Views 6255
HJerry
HJerry over 4 years ago
Hi all,
Is there away to change the Allegro Export PDF parameters in SKILL?
I was just going to create and run a script, but thought I would see if I can keep it in SKILL.
Jerry
  • mahimag
    mahimag over 4 years ago +1
    not sure about changing parameters in allegro but while exporting the only way I can think to access export pdf through skill is using axlRunBatchDBProgram, use pdf_out as batch utility with a configuration…
  • mahimag
    0 mahimag over 4 years ago
    not sure about changing parameters in allegro but while exporting the only way I can think to access export pdf through skill is using axlRunBatchDBProgram, use pdf_out as batch utility with a configuration file for parameters
  • HJerry
    0 HJerry over 4 years ago in reply to mahimag
    That's it!
